Cub Cadet ZRT S back wheel issue
tootan
We have a Cub Cadet ZRT S Series zero turn that is just 2 years old. Yesterday is started driving strangely. The right back tire spins faster than the left and is causing ruts in the yard and driveway. Even threw the tractor into a cookie at one point. It runs fine in reverse. Any ideas what could be causing this?
rperk
either the linkage to the hyd motors are out of wack or the left hyd pump/motor has lost some of its get up and go.
The first can be adjusted ,the second will need repairs
