Simplicity Sun Star 14 Horse won't transfer starting voltage through relay
dsailor44@gmail.com
  • / Simplicity Sun Star 14 Horse won't transfer starting voltage through relay
I have replaced my starter relay three times to resolve a starting issue. Each time its replaced the mower will start maybe twice and then the relay fails again. What am I looking at? Direct connection to the starter starts it every time.
Catherine
LawnWorld Support
Staff member
:welcome:
Welcome to the forum!
I'm going to move this thread over to our Simplicity section to see if we can find you some help.
BrianSki
If replacing the relay fixes it, It must be the relay or an excessive draw through the relay. Either way the relay sounds weak. Is it a simplicity brand or an aftermarket? The aftermarket may be of a cheaper quality. If you can get an automotive style to work, it would be a lot more heavy duty.
