1978 Model 8237 kill switch doesn't work to kill the engine
824tsv
  • / 1978 Model 8237 kill switch doesn't work to kill the engine
Hello folks,
New member. I replaced the pull cord and upon reassembling the cowl the mower starts up and runs fine but the on/off switch doesn't work to kill the engine. There are 2 wires that run off the bottom of the on/off switch. One goes to the coil lead, where does the other go to?
Thanks
Robert
EngineMan
The wire will go to ground somewhere, maybe near the coil its self.
824tsv
I wish I could remember where it was attached. Everything under the engine cowl is plastic with a couple of aluminum brackets. I'm assuming it's grounded on something steel? Would anyone have a pic they can post?
824tsv
Sorry for being rude, thank you very much for the reply EngineMan!!!
EngineMan
If your engine has a engine brake it will on that.
rfWi
Was this problem resolved? If not,here's a couple of pics of my 8237.
824tsv
Sir, I need to buy you a case of beer!
Thank you for the pic!!!!!
rfWi
Hey no problem,glad to help!
