Brunomarcs
- May 2, 2018
- 1
- 8
You didn’t waste my time and I didn’t mean to come off like that. Your time is well worth the 200 bucks for the job. I’ve gotten 11 yrs of service out of this motor which is good for me. Here is what happened to mine. I had a leak on top of motor, took cover off and found those bolts loose, backed out a 1/2”, I tightened them, really to much torque, drove over to my water hose and let the engine cool for an hour. Sprayed a degreaser and let soak 20 min. When I came back to it I hit it with a water hose I literally seen the crack develop, it could’ve cracked when I over tightened the bolts but didn’t see it then. I Used jb weld many layers over a four day period, stopped the leak only to then find the bottom was also cracked. I try to post photos but says my posts are too short. Thanks for the help
