What have I bought? An update
jcobo
It is turning over nicely, good spark, just can not get to stay running more the two times.
Considering using a trigger sprayer and squirting directly into the carb.
Occasional back fires, right into your face. Using a rope
One day I will remember to get the serial numbers in the same place as the computer for better identification.
May you have good gardens, manicured lawns, snow free driveways and money in yours pockets. (I guess three out of four aren't bad) :laughing:
John
cheng
Sounds like the carb may need to be cleaned. Float maybe stuck.
Post serial numbers.
Gearjammer
Trace the fuel flow from the tank to the carb. Some have a shut off valve that operates on the switch that may be faulty. Is there plenty of fuel getting to the bowl in the carb? Will it start and can you keep it running if you spray gas or starting fluid into the carb? It certainly sounds like some sort of fuel delivery problem or bad gas. Good luck. Gearjammer.
