The Daily Yardman Thread
Boobala
Re: MTD Yardman Transaxle Rebuild
Gooooooooooooooooood Mornin Chuck.. hc3066_plus-size-camille-strappy-lace-panty_teal_alt2.jpg
Goooood Mornin Gang, and you too Boud & Ron .. b8d24021d41ec38d6e1048ad0e3773f9.jpg
Thought 4 2day : .. 2018-01-29-03ac559b_fixed.jpg
BlazNT
Total views 211
BlazNT
Morning Ted, Stayers and Newbies.
Ronno6
Air compressor project
OK, testosterone set...........back to machinery.
A Champion 5hp 2 stage air compressor came with the house/shop.
I made sure it was on the contract.
I hadn't used it much, as it didn't hold air and didn't seem to pump too well.
As I will be needing it to operate air tools and spray paint, it was time to git 'er goin'.
First I bought a new set of head valves.
While replacing, I found the low pressure discharge valve laying gin the head in pieces.
That couldn't have been doing much good.
Once the valves were done, the pump did a much better job, but there was air still leaking
out thru the intake muffler from the unloader.
Upon disassembly, I found that there was NO check valve on the discharge line going into the tank.
And, the unloader was not really unloading as it should. Good thing, I guess, as the air would have leaked down quickly.
So, I await delivery of the check valve, hopefully today.
Adding that into the discharge line is gonna screw up the pipe fitting location for the cooling radiator.
I will probably need to shorten a piece of copper tube and install a new compression sleeve.
Piece of cake....just get one from the hardware store...right??
WRONG !
3/4" compression ferrules do NOT exist locally,,, not at either of 2 hardware stores (5/6" no problem....7/8" EZ. 3/4" am I speaking Greek?? NONE !!)
Not Home Depot; not Lowe's; not even the plumbing supply store...........NADA !
Had to order online !!
Oh,well, we'll see how it goes.
Hopefully it will be blowing hard shortly................(just like Boo !!)
Boobala
Re: Air compressor project
WRONG !
Ronno6
Pet peeve word of the day
Today's word is: ET CETERA.
Really screeches at me when people say "EC Cetera, EK Cetra, ECK Cetera, or EX Cetera."
It is "ET Cetera.............
I really hate hearing that, ecspecially when I have axed people to pronounce it correctly........
mhavanti
Ronno,
Everybody can't spell, we all know that. Who though is this ET Cetera? I know of this fella Peter Cetera. Pretty good vocalist and song writer in his own right.
You should listen to some of his early material with Chicago.
Easy listening,
Max
Boobala
Re: Pet peeve word of the day
I just use the word "AND" cause I can't spell "etceyera" ... OR.. I just use the breeveeashun, ..ect. ,ect. etc. ! ..:laughing:..:laughing:
Boobala
Ronno,
Easy listening,
Max
WELL, WELL, WELL Mr. Avanti himself !! .. Got lost at the "Beer & Brothel" for quite awhile now ! at least you're still "warm & breathing"..... This guy Peter Cetera... any friend of Peter Gozinya ?? or Ben Dover ?? Haywood Juhblowmee ?? .. :laughing:..:laughing:
