Engine is 500 Series 158cc 4.5 HP Briggs & Stratton/5.0 Torque. Starts ok. Will continue to run if I hold the starter cord all the way out. When I release the starter cord back in, the engine dies. It has been running ok for a few months. I changed oil and replaced the dirty spark plug, but no difference. Engine cap vent holes are clear.
This morning I cleaned the filter, but same problem. I do see there is a small cut halfway thru the spark plug wire where the top compartment comes down on it. I assume that wire can be purchased. Any way to cut out bad piece and splice back together?
