cub cadet LTX1050
JDR
I want to know if a used hydro transmission #311-0150 618-0319 will fit mine which is #618-0319 618-0319 is the numbers on the tranny. thanks jerry
BlazNT
The only real way to know is to look at both side by side and compare bolt patterns, pulley placement and everything else placement.
BlazNT
You don't want #618-0319 618-0319 it has a huge recall Due to Crash Hazard.
