- Nov 29, 2014
- Threads
- 64
- 24,705
I do not think the GXV (vertical shaft, lawn mower engines) in the HR215 had a dipper on the connecting rod cap. A dipper was usually included on horizontal-shaft engines (pressure washers, reel mowers, generators, etc.) This is not a 100% hard & fast rule. I have seen some mower engines that do indeed have a dipper, but it was included to reduce overall costs, by sharing the same connecting rod cap as a horizontal-shaft engine.
Well you are the bloke who would know.
It is a testiment to the quality of the Honda engines that I rarely have to dive deep inside.
In tha past 4 years the only Honda work I have done a lot of is cleaning the crud out of the carbs and replacing main jets and fuel bowls devoid of the zinc plating.
This is of course apart from general service & tuning.
Not had a single failure requireing splitting the cases.
OTOH that rod is definatlely cooked and cooked from the journal up not from the piston down which is what too high octane gas / running lean would do.
Will you show the pickies to the tech Gurus for a more authorative opinion than mine ?
