I have a Yardman Riding mower model 13AM772G755 that will not start with the ignition switch. I can start it by jumping to the starter. Once it starts and the key is in the run position it runs very rough. If I hold the key in the start position it runs fine but I obviously could not mow very effectively holding the key with one hand the whole time. I assumed the problem was the ignition switch so I installed a new one with no fix. Any help is appreciated!
