Husqvarna RZ5424 Drive belt
BlazNT
I had to replace my drive belt today. I can not get it to work the way it is supposed to. The belt will not tighten. I must have routed it wrong. Any on know how to route this belt. Not the deck belt but the drive belt.
Model #965881301
Serial #091585467
Engine# PS-SV725-0013
Up Date: I figured it out.
Cutty
Re: Husqvarna RZ5424 Drive belt Routing
I am attempting to find the proper routing diagram for a Husqvarna RZ 5424 zero turn mower. It is not specified in the owners manual or parts diagrams.
Drive belt is plain triangle between the 2 pumps & engine.
Tensioners always go on the slack side which is the left.
If it is a flat pulley it runs on the back. If it is a V pulley it runs on the inside.
The deck belt will go from the engine through the left & right idlers around the left & right spindles then generally around another idler and over the front.
The deck routing should be on a decal on the deck.
Luffydog
Type in your model rz5424 belt diagram and hit images and in the first 2 pics deck and drive
