Homelite/parts available
primerbulb120
Moderator
Here's my guess: The flat aluminum piece goes in the back of the air filter box to prevent the air filter from getting sucked up against the carb throat and choking the engine.
The air filter is probably held in place by the top/side cover that you remove to gain access to the air filter.
I've never worked on one of these before, so I may be wrong. :laughing:
RDA.Lawns
Not going to hijack this thread. But how can I find parts that are now obsolete? I have a great little trim saw that was my dads. Gas n oil caps are leaking.
primerbulb120
Moderator
Put the part numbers in eBay search box and see what you can find.
