Page 6 of 7 FirstFirst ... 4567 LastLast
Results 51 to 60 of 68
  1. #51
    BlazNT's Avatar
    Join Date
    Apr 2012
    Posts
    6,798
    Location
    Missouri
    Mower
    RZ5424
    Re: HydroGear EZT Transaxle
    The EZT has a maintenance schedule but most manufacturers call it sealed or unserviceable. Go to the hydro-gear website and download the instruction manual and follow it.
    Chuck
    We Do Not Stop Playing When We Grow Old
    We Grow Old If We Stop Playing
  2.
  3. #52
    Join Date
    Sep 2018
    Posts
    8
    Location
    United States
    Mower
    Toro
    Just joining... I have a 2009 toro z5030. It was driving fine until I pulled the bypass levers to physically push the mower, then moved the bypass back to original position. The next time I went to use the mower only the left side would drive. Then both sides stopped driving. I tapped on the units with a rubber mallet and the right side drove forward only. I have removed the transaxles from the mower. I physically moved the bypass levers with my hand forward and aft and was able to turn the axle in either position as if the bypass is stuck. I drained the oil from both transaxles. One side had 48 oz's and the other had 44 oz's. The oil was dark with no metal in it. Does anyone have any information on this problem? Thank you in advance for your input.
  4. #53
    Join Date
    Oct 2014
    Posts
    873
    Location
    Arkansas
    Mower
    Hustler Raptor SD 60"
    garrisond45,
    I'd refill them, then bleed them. Most likely all you needed to do was to go thru the bleed process after pushing the rods back into place.
  5. #54
    Join Date
    Sep 2018
    Posts
    8
    Location
    United States
    Mower
    Toro
    mhavanti,
    I will try that. Thank you for your input. I'll let you know how it turns out. Thanks again.
  6. #55
    Boobala's Avatar
    Join Date
    Feb 2015
    Posts
    6,699
    Location
    Central Fl. about 2 hours from DAYTONA !
    Mower
    Murray Select 21 H.P. 46" ( 2004 )
    Mower : Murray Select 46 " deck
    Model : 465306X8A
    Serial # : 733781D027
    Date of Mfg. : 2003/12/03
    Engine : Briggs & Stratton
    I/C V Twin
    21 H.P.
    Model : 4045A7
    Type : 0211 E1
    Code : 031104YG
    Family YBSXS . 7242VF 22844
  7. #56
    Join Date
    Sep 2018
    Posts
    8
    Location
    United States
    Mower
    Toro
    Boobala, Thank you
  8. #57
    Boobala's Avatar
    Join Date
    Feb 2015
    Posts
    6,699
    Location
    Mower
    Quote Originally Posted by garrisond4550 View Post
    Boobala, Thank you
    You're very welcome, please pass around if another needs it ......
    Model : 465306X8A
    I/C V Twin
    21 H.P.
    Model : 4045A7
    Type : 0211 E1
    Code : 031104YG
  9. #58
    Join Date
    Oct 2014
    Posts
    873
    Location
    Arkansas
    Mower
    Boo,
    Have any experience in having several Hydro Gear wheel motors in the shop at the same time? Thus able to state if a 4400 has the same mounting points, rod lever points, etc. as a 2800, 3100 and 3400?
    If you can verify these have the same outer mounting points. I'm installing a pair of 4400s on a Raptor SD or go thru the set of 2800s and upgrade them to 4400s.
    Thanks in advance,
    Max
  10. #59
    Boobala's Avatar
    Join Date
    Feb 2015
    Posts
    6,699
    Location
    Mower
    Quote Originally Posted by mhavanti View Post
    Boo,
    Thanks in advance,
    Max
    Sorry to say max, I have NO experience on these Hydro-Gear trannies ... I THINK, .. BlazNT MIGHT, .. be able to provide some insight into those items, you might give him a PM ...
    Model : 465306X8A
    I/C V Twin
    21 H.P.
    Model : 4045A7
    Type : 0211 E1
    Code : 031104YG
  11. #60
    Join Date
    Oct 2014
    Posts
    873
    Location
    Arkansas
    Mower
    Boo,
    Thank you kindly my friend. One of these days, I'll find a shop that is large enough to have a plethera of used units or even new units laying in the shelves to lay them all out and do some sleuthing. Hydro Gear, Excel, Scag, JD as well as the other brands I've contacted will not provide this information as they are afraid I may harm myself. lmbo
    Max
Similar Threads
  1. Repairs Husqvarna Z5426 transmission trouble (EZT slipping)
    By forsbergt in forum Husqvarna & Dixon Forum
    Last Post: 07-15-2018, 06:26 AM
  2. 2800 hydrogear transmission will not work
    By jrcs50x in forum Transmissions & Transaxles
    Last Post: 07-17-2015, 07:49 PM
  3. Hustler FasTrak 44 EZT drives
    By budlin35 in forum Hustler Forum
    Last Post: 03-02-2014, 03:23 PM
  4. Original engine on Hustler FasTrak 44 EZT
    Last Post: 02-27-2014, 10:48 AM
  5. HydroGear problems
    By LenPott in forum Small Engine & Mower Repair
    Last Post: 05-08-2013, 03:39 PM
Tags for this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
