Results 1 to 3 of 3
  1. #1
    Join Date
    Apr 2011
    Posts
    Location
    Ohio
    Mower
    Toro
    12 hp B&S popping sound???
    I have a 94 toro riding mower with a 12hp B&S model 282707 series0119-01. It starts up and runs but has a popping like sound and seems to backfire through the carb. I have thoroughly cleaned the carb, new plug, checked for spark, checked the flywheel key alignment with the shaft, tried all kinds of adjusting on the carb and nothing has changed. What I have noticed the new pulg is black and seems to be damp and you can very easily spin the motor by hand. I think maybe it is a compression problem but am no expert maybe a valve or something. I have had the head off and it looks as if the valves open and close but like I said I am no expert. I am also at my wits end any help or advice would be appriciated. thank you
  2. #2
    poncho62's Avatar
    Join Date
    Mar 2011
    Posts
    71
    Location
    Ontario, Canada
    Mower
    Fords, MF, JD, National
    Re: 12 hp B&S popping sound???
    How did your head gasket look?....could it have been leaking?
  3. #3
    Join Date
    Apr 2011
    Posts
    Location
    Ohio
    Mower
    Toro
    the gasket is worn somewhat don"t know if it is worn to the point of needing replacing or not. The problem is no place around here has parts for my mower so i have to order it online was planning on ordering a new headgasket when I order other parts I need this is a project mower I picked up for free.
Similar Threads
  1. B&S 20.5 twin overhaul?
    By jlsanborn in forum Small Engine & Mower Repair
    Last Post: 03-26-2011, 04:30 PM
  2. Ask & Receive
    By greengrass in forum The Front Porch
    Last Post: 02-28-2011, 06:58 PM
  3. Replies: 4
    Last Post: 08-03-2010, 08:07 PM
  4. 5 & 6 h.p. Tecumseh?
    By bmwe0692 in forum Tecumseh Engine Forum
    Last Post: 05-13-2010, 10:27 PM
  5. Newbie, just saying hello & ?
    By ACE in forum The Front Porch
    Last Post: 05-06-2010, 10:54 AM
Tags for this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
