Thanks for the EXCELLEXT pics. I used a ice pick through that hole but it would not engage into any hole in the backside of the cutting head - I spun the cutting head slowly while pushing on the icepick. Even if I prevent the cutting head from turning this will not keep the flex cable from turning while I try to turn the nut. I have got to prevent the flex cable from turning while trying to twist off the nut. Thanks
It sounds like the black plastic cutting head has rounded out, the hex headed hole should lock on the end of the shaft and it should turn only when the shaft turns.
It did not round out - I do have the bare exposed nut. It does not have any plastic around it - the bump knob has been completely cut offf. I need to keep the flex drive cable from turning!!!! Bob
I am attaching pics of what I am working on, just to show you where I am at with this project. As I say, I completely have the bump knob cut away showing the bare nut.
