Page 7 of 7 FirstFirst ... 567
Results 61 to 66 of 66
  1. #61
    Join Date
    Apr 2017
    Posts
    Location
    Ohio
    Mower
    Re: Review of my Honda HRX217HYA
    First time mow today. Started right up and mulched like a dream. When I first start up, the blade engages with no drop in engine speed. After mowing a bit, the engine bogs down momentarily when i engage the blade then runs fine. The mower deck is clean and it happens even if I'm off the grass. It hasn't actually stalled.
    Anyone have a similar experience?
    Richard
  2. #62
    Join Date
    Dec 2016
    Posts
    Location
    Wisconsin
    Mower
    Honda HRX2175HYA
    Update....Used for the first time yesterday,started on first pull and after a few passes the Hydrostatic Cruise Control was very intuitive and easy to get used to after 5 seasons with a Smart Drive system.Beautiful job of mulching also.
    To the poster after me,I noticed the momentary drop in engine speed when you engage the blades as well.Seemed normal to me,I did not think much of it.Top notch mowing experience,nice machine.
  3. #63
    Join Date
    Apr 2017
    Posts
    Location
    Ohio
    Mower
    Quote Originally Posted by horsey55 View Post
    I agree. Very satisfied with the mulch setting even though the grass wasn't perfectly dry. I have to use the lower cruise control setting since at age 81 I can't keep up with the faster speeds. I moved up from a Poulan Pro front wheel drive that I had to push up the slight hills in my lawn. The honda just sailed up and I just had to steer it a bit.
    Richard
  4. #64
    Join Date
    Jul 2015
    Posts
    38
    Location
    South Carolina
    Mower
    HRX217HYA
    After about a year I finally got to see how well this machine bags leaves. I lowered my deck to the 2.5" position and this this sucked up leaves like a dream. Short of a large rider with huge bags or paying a company to remove your leaves this machine works great.
  5. #65
    Blackdiamond1983's Avatar
    Join Date
    May 2018
    Posts
    Location
    Oregon
    Mower
    I have this same mower I bought a few weeks ago and i love it. Although it seems the 190cc engine isn't as powerful as some say. I killed it several times mowing some tall wet grass. As long as the grass is dry it does awsome.
  6. #66
    Join Date
    Jun 2018
    Posts
    12
    Location
    United States
    Mower
    I've owned my HRX217K2HMA (the electric start version) since April, 2010. I love the performance, but somewhat troubled by the reliability issues encountered. But to be fair, I do put a lot of hours on it per week with an acre+ that I enjoy doing with a walkbehind rather than my tractor. Exercise program for older men!
    1) Hydrostatic tranny serviced by dealer under warranty at year 5 (oil change - cold running 'growl' and low ground speed attributed to cavitation). Replacement authorized by American Honda in year 6 as the issues returned the next season. I started hearing something odd the other night, so a little bit concerned about future costs.
    2) Electric starter replaced in year 4 (or maybe 5?) due to lack of engagement (pinion not rising up worm gear). I just serviced the second unit myself last night due to the same issue.
    3) Battery is expensive! Take proper care of it and it will last a long time, but be prepared for an $85 bill when it comes time. Replacements are available for less if you shop around....
    4) I managed to break the handle near the end of last season. Lower right side at the pivot bolt - the weak link spot in the assembly. My property is hilly, with a lot of crazy landscaping details that require a lot of jockeying to get around. This is a near 100 lb mower, IIRC, and the handle takes a beating. I sleeved it with a piece of 1" EMT, and it seems to be holding up reasonably well. A new handle is like a $150 part. Crazy...
    5) I'm on my second rear skirt / trailing shield. It has to transition from behind to under when you back up, so if you do this a lot, expect them to tear. I'll be ordering my third one soon.
    6) I'll probably need wheels soon also.
    7) I do either a blend of bag & mulch or discharge and mulch thanks to the Clip Director. LOVE THAT FEATURE!!! But I hate the idea of rear discharge. So I cobbed together a custom side discharge starting with a piece sold for another Honda mower. Pretty easy and very effective! Now I have my perfect combo.
Similar Threads
  1. New HRX217HYA
    By Cyendrey in forum Honda Forum
    Last Post: 05-23-2013, 11:59 PM
  2. Replies: 9
    Last Post: 05-16-2013, 03:29 PM
  3. Attachments Honda HRX217HYA Deck Guard
    By baratta34 in forum Honda Forum
    Last Post: 05-10-2013, 09:18 PM
  4. Buying Advice HRX217HYA discontinued at HD
    By Thelorax in forum Honda Forum
    Last Post: 01-25-2013, 11:10 AM
  5. Repairs Honda HRX217HYA
    By Petik in forum Honda Forum
    Last Post: 04-26-2012, 05:16 PM
Tags for this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
