- Nov 29, 2014
- Threads
- 64
- 24,705
Quick & dirty test is to pinch off the fuel line remover the float bowl, hold the float and see if it cuts off the fuel flow before the float touches the top of the carb body.
In most carbs the top of the float should be parallel to the bottom of the carb when it cuts off the fuel supply
