Wife and I purchased this mower from the local dealer used with 520 hrs on it this spring. It has ran hot every since we purchased it. At first it would climb right shy of the red and hold steady. We took it back and they said they did some things to it. It continued to run hot. After 30 minutes it would reach the red. We took it back again. They said they tightened some belts.
Well, the mower still runs hot. It will run for about 30 minutes before reaching red then I have to disengauge the blades to let it cool off. I am about to the point of dropping it off and hiring an attorney. I got out the manual to check everything myself yesterday. I had to increase the tension on both belts (motor and manual 61" deck). But, I couldnt get the belt on the deck to specs. It states that the spring needs to be 5.75" but I cant get it that tight. There is still some slack in the belt when I have the spring tensioned as far as possible (5.5"). I'm assuming I need a new belt? Could this be causing the mower to overheat?
I also have noticed that the trimmings fill up the radiator gaurd within a few minutes of mowing. It cant help the problem but there is no way to keep it clean for a period long enough to mow a few acres. Maybe an eighth of an acre and its full of trimmings.
Any help would be greatly appreciated. I've searched and searched the net with no luck.
Alex
Alex
