Export thread
Zd326 new rebuilt engine now cutting out
#1
Fatdaddy
Fatdaddy
I know had the cups now this...
I had the engine rebuilt and first time cutting the yard after about 45min it cuts out like it is trying to die.
It picks back up runs strong then tries to die but does not so i put it up..
Get out next day it runs fine cuts fine for 45 min then cuts out tries to die..
is this might be a fuel filter?
Could this be the injector Pump,, when new engine does that have something to change in this pump??
#2
jekjr
jekjr
More than likely a fuel filter.
#3
Fatdaddy
Fatdaddy
he put new filter but says it is still dong it.. Could it be the fuel pump? does that just cut back ??
Tks for your reply
#4
jekjr
jekjr
Tks for your reply
It could be the injector pump. It could be the fuel transfer pump. In my experience an injector pump is not intermittent. It either works or not. I have not worked on Diesel engines that much though since they started all of the electronic stuff. If memory serves me correctly that mower has an electric fuel pump. That would be the next thing I would check.
#5
Fatdaddy
Fatdaddy
Turns out it was the FUEL PUMP, i could have should have gone get one but I LIKE the guy. Cost me $244 total $109 pump 135 labor
