Pappy,
I went and looked at the fitting as you suggested.. It ain't anything I've seen before, I'm glad you know what it is!
Hey, posting pictures on here is a breeze! Believe me, if I can do it, anybody can!! If you look at the line of icons at the top of the "Reply to Thread" box, which is the first line of icons under the "Title Box" and you count right to left, yeah, I know that's backwards, but you only have to count three! and you see an icon that looks like maybe a paperclip on the left edge of a very small 'page' and then click on that. Another box will appear with a line that says "Add files" on the right-hand end, click on that and a little box comes up with a line that says, "Browse". Click on that and it will connect you to your picture files. Select the picture you want to post and double click on it. The box will come back and say "Up Load", click on that and when it's all done up loading, click on "Done". Then when you click on "Submit" for your posting, the picture will appear after what you've written. Be sure to write what you want to say first! - Then do all this picture stuff and last click on "submit".. You'll be a pro in no time!
Roger
