Hi, my x300r has recently started to stop moving when cutting, for example everthing is fine then suddenly when pushing the pedal i am going nowhere unless im on a hill where it can dangerously freewheel, then bang its fine again... until thr other day when the problem came back, now it tries to move forward or reverse but just goes inches, the drive belt is turning fine no restrictions, no crazy sounds from the transmission, i have heard about dodgy k46 transmissions is this typical of k46 failure? please help, thanks
#2
BlazNT
It sounds like the drive belt tensioner is not working or the belt needs to be changed.
