rhardie: some info that will get more responses would be model number. I don't have an MTD mower but some things are common between all mowers. What have you done to diagnose the problem? My best guess would to see if the chock is functioning correctly. Is the throttle plate in the carb closing down or a weak throttle cable return spring or a sticking throttle cable inside the sheath? Hard to tell from your post but this info may help someone to diagnose you issue.
