alternative browser .
Nov 10, 2012 #1
A
A&DProperty maintaince
Which is better for rolling lawns I'm thinking walk behind so you don't get stuck
Nov 10, 2012 #2
slammed
Why a asphalt roller and not just a water filled roller.
Nov 10, 2012 #3
lawn mower fanatic
I would say just use an actual lawn roller that as
slammed said you fill with water. Tow-behind or push would be OK, I would get a tow-behind because then all the work is on the machine, not you.
This is something you could get:
Here is the website for it:
http://www2.northerntool.com/grounds-maintenance/item-365357.htm
Nov 10, 2012 #4
A
The thing is everyone wants an asphalt rollers 90% of the calls I got last year wanted one
Nov 10, 2012 #5
lawn mower fanatic
I don't know much about rollers....why would they want them over a lawn roller? Just because they are heavier?
Nov 10, 2012 #6
slammed
They may not know what they are talking about. Those are to heavy for yard work.
Nov 10, 2012 #7
lawn mower fanatic
The yard may be perfectly flat after you use it, but the grass might be dead! Lawn rollers are made for lawns.
Nov 12, 2012 #8
slammed
No it don't kill it. I have ran an asphalt roller on a lawn before . It is very hard to not leave ruts in the yard. And keep it level. It just don't look good afterwards.
