The recommended medium lift blade (600901) looks to be 0.2 inches thick. I was looking at another brand that should be the same except it has a thickness of 0.25 inches. At that many RPM, I would appreciate a second opinion. The replacement blade is a Fusion priced about the same as the OEM. The OEM blade and Fusion blade(91-239) cost almost twice as much as other Oregon blades. Also, how much longer (on average) would the harder blades hold an edge compared to the softer steel?
Thanks,
RD
