If you want to make tighter turns try doing what I tell turdfaces to do, stop, shift to neutral, disengage the mower pto, turn wheels in the desired direction, then get off your mower, pick up the back of your machine and swivel it around to make your turning circle tighter.
Easy, wasn't it????
