No, not on a lawn tractor.
An actual gear transmission & clutches with pressure plate on an Older Garden Tractor you could.... But mowers, even those with gear drive transmissions have Belts linking the transmissions to the engines, can't reverse the drive direction because the idler will be on the Wrong side of the set up for the trans to turn the engine... :smile:KennyV
