toaster816
- Apr 12, 2015
- 1
- 3
New member here, looking for some information from the experts.
I have a 175 Hydro that has starting issue. Some background on the tractor:
-it has a relay kit which from what I've ready bypasses the seat safety switch
-the battery has been replaced and at the positive and negative terminals the voltage reads 12.56
-tank is full with fresh gas
-air filter is clean
-when clutch is depressed and key is turned to 'start' the motor just clicks repeatedly and flywheel does not crank
-voltage at battery terminals when key is turned to 'start' drops to 4.03, then rises back up to around 12.56 when key is turned off
-I have measured the positive battery cable terminal at the other end where it connects to the solenoid starter and the readings are the same as the readings on the terminal (12.56 at rest, drops to around 4 when key turned to the 'start')
-I can get the motor to crank and turn over by jumping it from truck and the tractor functions perfectly, then once I shut it off, I cannot get it to crank and turn over unless jumped.
-I took the spark plug out to see if I could at least get it to crank without working against the compression and the flywheel spun about half way then stopped, and more clicking
I am wondering why the voltage dips so much when the key is turned to start, especially since the battery is new, the voltage at rest reads 12.54 and all electrical connections and fuses look intact. The only thing I haven't done which to my limited knowledge is the last thing I can think to do is clean the other end of the ground cable where it connects to the motor, sometimes I've found the grit that accumulates over time insulates the terminal preventing it from grounding properly?
Any help would be greatly appreciated and I apologize for the long winded for post.
Taylor
Taylor
