I have had this snapper since about 1993 My grandmother purchased new around 1988-90 However the clutch disc will no longer pull of the motor on any kind incline It will just stop I replaced the belt a couple years back and it never pulled right after that (the belt is installed right) Before I go thru doing the belt again what is the main cause of this problem Right now the the Idler pulley is all the way up as far it will go But never had a lot of tension from the belt change Worn motor pulley? Worn clutch disc? bad idler pulley?
I suspect the clutch disc pulley But want some input
By the way it has a million miles on it 3 set of back wheels,5 transmission belts, one motor disc belt Original engine, 28 Plus years of use weekly user up till 2005
when new snapper walk behind took over part of it duties
