is there a way to clean you hydraulic pump on a snapper z-turn
#2
SONOFADOCKER
Power wash the machine - if you mean changing you hydro oil - locate your filter and drain. Remove the filter and then loosen the inlet pressure hose . Drain the fluids into large catch pan or bucket .
Put on a new filter , tighten the drain port or the pressure line - add the correct amount of hydro oil .
