Hi, I have a Simplicity Landlord 3410. It's a basic 3 speed Simplicity tractor. The right side driveshaft seal allows the gear oil to pass by it. My question is, is the seal easy to replace? Or can I simply count on that there is enough oil in the gearbox to continue running it the way it is. I don't want to open up a can of worms. My other concern is the part of the driveshaft assembly where the inside of the seal rides. I'm sure that it's worn out. I don't know if there is a replacement part available or some sort of a repair sleeve that can be put in place to stop the leak. I'm not sure how to proceed with this. Thanks in advance for the advice.
