Hi Howard,
Hmmm. Not an expert on Honda mowers, but I just bought a shaft driven Honda mower. Remove the transmission cover on the back of the mower and move the self propel lever, does the lever on the transmission move? If not, folding the handle may have broken the cable even though the ends are still connected. You should be able to replace the cable without removing the transmission.
Regards
Jeff
