my husband tried to fix a broken pulley cord on our mower and ended up screwing the whole motor. Now he has 3 lawn mowers and is trying to get one out of it that will run
IF it don't spark after it cuts out,..suspect the coil,...no matter if it is new.I have a "Horror Story In Progress"!! This evil contraption was given to me because the former owner was fed up with this 'Hell On Wheels' log splitter w/ a 14 HP cast iron Kohler side shaft engine. It had been to his mechanic 3 or 4 perhaps more times with little or no success. I had gone up there several times 33 miles one way to work on it for him with little success. What it does is crank right up and run for a couple of minutes, then starts cutting out and dies just like you turned the switch off. It will not start and you can run the battery down trying. Let it sit for an hour and come back and it'll hit and run for about 45 seconds if that much and die again. It has had a switch, points, condenser, coil, carburetor rebuilt, valve job, cleaned and decarbon the head. Carburetor rebuilt, then replaced and that one rebuilt as well!! Had the float and needle replaced and that's just off the top of my head. I'm sure there's been more done to it. I have an 11 HP Honda sideshaft that came off a pressure washer I acquired this summer that I am going to re-fit to this log splitter. The splitter is healvy duty and great but the 14 HP Sideshaft Kohler is an evil demon from Lawnmower Hell that has sat out there and leered and sneered at me for two winters, going on three counting this year.
Yes it could be a bad coil, but depending on the model and spec number, it could also be the points plunger. I'll have to do some research to see if I still have the bulletin from back in the 70's (I think) about this problem.
I have rebuild a couple of these kohlers and always reused the headbolts,I never had a problem.Thanks IL ENGINE, and RIVETS and BISON. I'll get the model #s off it and post them.
NOTE: K-301
4765
I appreciate your help but am basically at my wits end and tired of worrying with it. As IL said, it could be the head bolts. Never thought of that since it was a cast iron engine. I believe the head bolts are steel. Automobiles with steel blocks and aluminum heads have that problem and the bolts have to be replaced every time the heads come off!! I will fire it up again and when it starts to quit, check it for compression. I know there are two carburetors made for that series engine. One has that LONG main mix needle on TOP. I believe it's a variable jet. The other one has the shorter mixture screws on it. A Walbro it seems. I believe it's a fixed jet type. I know the shorter screw type won't rev up as well due to fuel/air mixture and volumetric efficiency , fixed jet etc. Those egg head formulas for racing engines and rpm/torque curves etc. THANKS GUYS!!
Was changing the oil in the wife's Mazda. Pulled the filter off, but neglected to notice the o-ring on the filter decided to stay attached to the engine, not the filter. Put on the new filter, and got it hand-tight as normal. The double o-rings left a nice 1/4" gap all around the filter (!).
Added 5 new quarts of Castrol, sat in the driver's seat with the car still up on ramps, and started the engine. Heard an "unusual" gurgle, and my eyes got real wide when I looked down and saw a ever-expanding puddle of fresh oil being pumped out of the gap and onto the garage floor. Took about 2 seconds to empty it. What mess!
Hi I am Norman and o am pretty new ro rhis site.
Any help wou;d really be appreciated.
I have a 721D Grasshopper mower with a 3 cyl. Kubota engine.
It has been in various shops 5 times and the problem keeps persisting/
My machine is taking in air from somewhere.Air bubbles comimg out of the lines to the tank.
All hoses are replaced tank cleaned,air filter changed heatshield installed, new injector pump,
new fuel pump all lines bled.I am at a loss and i am losing all customers bevause off all the downtime.
It id dtill tking in air.
Thank you all/
vapor lock i have an old briggs service update with that problem in it,as soon as i find it i will reply with an answer
Norman is having problems with his 721D... that's a diesel engine.
You can never vapor lock diesel fuel, I think you could mow with it on the surface of the sun without a vapor-lock situation... (if you had enough moisture to get the grass growing)...
vapor lock happens with gasoline & heat... :smile:KennyV
