took the deck off and took the blades off then took the spindels off and cleaned the underside off with a wirewheel down to bare metal.I then treated the area with a rustproof preventer I bought at O'Riley.Went to my Grasshopper dealer and bought new kelvar belts and a new skirt.I plan to put new grease sirks on the spindels and check the others on the tractor unit.To make my grease maint. easier I also bought an air powered grease gun.I also got an air ratchet.taking the blades and spindels off with it was a breeze,should've bought one yrs. ago.when it warms up enough plan to finish up the under side of the deck with E-Zslide. also plan to clean up the kubota diesel with degreeser.want everything working good and looking pretty come mowing time.can't wait. russ
