I have a problem. My son mowed and said the hustler was running very slow. When I checked it I found the fluid level to be very low and the damper arm on the right side had disconnected on one end. I figured the arm was the problem since the left drive control was working normal but the right control would not engage the right drive motor. Now having replaced the right damper arm and adding fluid to the hydraulic system, there is no improvement. What gives???
