Export thread
Roper Trans needed
#1
J
jerry1249
I'm needing a 4 speed transmission for a model YT160BR Roper Lawn Tractor. It's a standard "H" pattern W/reverse in the lower left position. Any help will be appreciated.
#2
R
Rocky J
Link to picture of transmission . http://www.partsandservice.com/bin/ipl.cgi What is the symptoms of yours needing replaced, jumping under a load?
#3
J
jerry1249
Trans is cracked on top and bottom of the case. Been locked in 4th gear position w/ only neutral. Have called a few salvage yards w/ no luck. I was told that an older model Sears had this same trans.
