Does anyone know how to check the electric clutch that engages the deck belt? I have a 52" Hustler Raptor was mowing heard a pop like I hit something under the deck, so I shut it down and checked, nothing was under the deck and all the blades and spindles are good, so is the belt. went to restart and the switch that starts the belt seems to be sending a signal to the drive pulley, (I hear a click) but the pulley never engages? I check the fuse and it was good Any suggestions?
Look under the motor where the clutch is. There are two wires which come from it. One goes to the switch, the other goes to ground. My guess is what ever you heard cut one or both of those wires.
