Very easy. Remove the gearcase at the bottom of the shaft and the flexible drive shaft will slide out. The windings should be uniform. If not, it is near it's breaking point and needs to be replaced. Grease shaft and slide back in. Note the square ends on shaft. May have fumble with it a little bit until it drops into clutch hub, then align the shaft with the gearcase and reinstall. EASY!
