I posted this in the general discussion but thought this would be better. Gotta Troy-built rider with a Kohler Commander14 engine. Runs well but once it gets hot and I disengage the deck it stalls out and cranks but won't start back up. Any ideas? Any info is much appreciated.:thumbsup:
#2
jmurray01
As I said in your other thread:
"It could be a carburetor issue causing it to run too rich, which would make it stall and then not start again due to a flooded combustion chamber.
Try cleaning out your carburetor and see if that helps. :thumbsup:"
What if you run it till hot with the mower not engaged will it stall out after time? Just trying to see if it it mower related or something in the motor.
Rob
#5
Carscw
Just had the same trouble with mine took carb apart and found I forgot to put a tiny spring back in. Put back together runs fine now
#6
SONOFADOCKER
Keeping in mind the age of the motor . Carbon build up on the piston creates excessive heat . Your fuel can be burning before the compression stroke is ready .
It will not stat until the engine is cooler.
Try a new head gasket and clean the head and piston top with a soft dremel brush .
