I took off flywheel to do oil seal put it all back together now no spark. I disconnected the white wire off them also i believe that's to ground out coils and shut engine down. I noticed coils have arrow on them. I first put them on in wrong direction(upside down) could this have fried the coils??? I can't believe this. always a problem
#2
BlazNT
Upside down should not have fried the coil. But not getting the correct gap can make the coils not spark. re-gap the coils and see if that helps.
