I have a Scotts S2554 and the fuel line from fuel pump to carb had a crack (but mower was running fine) that I replaced and also installed new gas filter. Now carb is not getting any fuel. Any suggestions?
WELCOME to LMF...
I would suspect the filter is not allowing fuel to pass, or you have a blockage in your new fuel hose...
Remove it from the carb and work your way back to the tank till you find the problem... :smile:KennyV
