Pumper.... Hmmmmm, I wonder, Fireman? Oil rig? (Texas, could be right?)
I wish I thought the transaxle was in good enough condition to rebuild.. The upper half of the housing is cracked where the axle protrudes on the right side. Also where the bushing should be in that same end of the housing, the axle has worn the opening egg shaped, so something serious has gone on there. I don't know if the axle itself is badly worn too. A new upper housing is $90. I have seen used transaxles for anywhere from $100 to $150, so if I needed to replace the axle as well, I'd be spending more $$ than a serviceable used one would cost.
Like Boob-La says, I've got lots of research to do.. BUT!! Fortunately I've discovered that I have far more time to do research than I thought I had, now that I've discovered that I'm far younger than I thought I was! Things are looking up!
Roger
