Export thread
MTD turf pro 10.5 hp
May 10, 2011
#1
R
ringo17
Well, the engine is running geat now. I removed the mower deck to do some work on it later. My problem is that it drives really slow in all gears, there is very little difference between 2nd and 5th gear. Ay ideas out there, appreciate your help
May 11, 2011
#2
J
jeff
Loose or damaged belt. Check springs on idler pulley system.
