Maybe someone can help me here, I have 1988 or 89 MTD Lawnflite 30" that I have dragged out of the back of a shed and got going again, but I want to replace the blades... do I have to remove the complete cutting deck to get into the nuts that hold the blades on??
How do I do this?
Thanks
#2
BlazNT
Three bolts in the middle of blade setup. Jack up the mower and you can access them from underneath.
#3
Catherine
:welcome:
Welcome to the forum!
I'm going to move this thread over to our MTD section.
Thanks for that, but thats not working, there are other bolts and when I look at the diagram they look to have nuts on them as well that you cant access... but looks like you can only access them from the top?
#5
BlazNT
The main bolt in the center of the 3 allowes you to remove entire peice. If it is not comming off then you need to use some penetrating spray. Not WD40. Then maybe a puller to remove it.
thanks, spray applied.. been on there for a while so might take some work to get it off... more spray I think, the mower sat idle for about 10 odd years in the back of a shed so things are a bit stiff...
