I am trying to figure out a problem with my neighbours mower it's a Cub Cadet LT1050 What happened is she was mowing some taller than normal grass and the mower just quit so she pushed in the PTO switch and then back out and it worked again for 3-15 seconds. What I'm wondering is there is a relay up by the main fuse that was warm could it be that relay getting to hot from taller grass or is there something else I should be looking for. Thanks in advance. Ron
I have a similar problem w/ my LT1050. In my case, I need to turn off the mower occasionally when mowing & sometimes it won't restart. I thought the problem might be the PTO switch, but a repair expert told me it's probably the mower clutch (which costs ~$125) & it will probably restart when it cools down. I'll wait until the problem worsens.
