I am thinking of building heavy duty ramps to load my 2007 Z 777 onto my flatbed truck. Does anyone know the maximum angle that these mowers can can climb? I am a little concerned about getting hung on the deck as I break over onto the bed.
Most Z's do not have a lot of ground clearance... Your easiest method would be to try it with some temporary Heavy planks...
depending on the deck you are likely going to need Long ramps... You will have a problem both at the top of the ramp & at the bottom... :smile:KennyV
