LT 150 has no spark. I have replaced the coil, still no spark. Took the ground wire off the coil, no spark. Put a coil tester on the plug wire and grounded the tester, no spark. I don't believe there are any bad safety switches. All the switches appear to work as usual. Isn't a fuel problem, because there is no spark. What have I missed. Also pulled the flywheel to see if the key was ok, it was.
#2
reynoldston
The LT150 has a single cylinder Kohler CV426S in it. You might want to check out the ignition module which is built into the key switch.
Any thoughts on checking the module other than buying a new one.
#4
reynoldston
As for me we have a very good John Deere dealer by us. What I have done in the pass I bring the old module or coil with me and they have a way to test them for me. They don't charge me for this service but I also buy a lot of parts from them.
#5
BlazNT
Model number and I will try to find info on testing it.
