My problem is that when I engage the blade to mow on my Hustler Fas Trak the power drops way off. I changed the oil and changed the air filter. Someone told me that it was only firing on one cylinder and was probably the coil. Would a bad coil cause it to fire on one cylinder. Is there any way to check to see if it is bad and is that hard to change out. I would appreciate any help with this my grass is getting high and all the local dealers here have a 2 week backlog. Thanks for any help
