good question, not certain the weight 'necessarily' increases a lot but, if you're stuck using typical 18650 (or w'ever) cells - yeah, mass is gonna increase with every bump in voltage no question (there could be a slight decrease in wiring diameter/mass in the tool I guess?), but, there are some prismatic (rectangular) batteries coming out so....maybe the actual battery pack isn't scaling up in weight?
