Hi, I am new to this forum and need some help. I own a Scag SWZV36A walk behind mower. The year is a 2008. It starts up fine but when I turn the key to shut it off it will not shut off. It is a manual pull start. I have checked the key switch and it checks out OK with and ohm meter. It also has the senso touch handle bar that does not seem to be working. I was wondering it the two are connected to my problem. Any help would be greatly appreciated. Thanks.
#2
reynoldston
broken kill wire to the coil, bad ground, bad key switch, loose connection, could be a number of different things
