Export thread
John Deere pop sound and stopped
#1
S
Sean_Rey
I have a John Deere 102 riding mower. I got into some tall wet grass and the lawn mower stopped to due to grass getting caught up under the blades. I pulled out and took a less wide path. The mower started to do the same. I pulled out, stopped the blades, then I heard a loud pop/crack from engine. The engine will not start now. WHen I turn the engine over all I get is a whining sound.
#2
reynoldston
reynoldston
check the key in the flywheel
#3
S
Sean_Rey
I let the lawnmower sit for a day. WHen I went back to it I noticed a puddle of oil under it. Not exactly sure where the leak is coming from.
#4
big daddy ray
big daddy ray
it sounds like you might have thown a conecting rod the wining sound is the flywheel and crank spinning freely ouch:
